SOURCE: Pyramid SE301-VL amp wiring confusion...
Captain_Bill,
Red - should be fused & is the +12Vdc system supply voltage.
Chassis = System ground.
Individual Green, Grey, & cooresponding blacks will be the right & left chan Audio ins (Black = neg).
Paired bl/blwh, br/brwh, grey/grwh, & green/grwh will be the audio outs.
Hope this helps !!!!
Dale EE
SOURCE: I need a wiring legend for the Rampage BA200 sub woofer
Red - power
Black - ground
Blue - turn-on (switched 12 volt)
Green and Gray -- Hook to factory/aftermarket stereo for the signal.
SOURCE: How to wire KD-S741R CAR STEREO - WIRE COLOURS ???
older pioneers:
2 x green (1 with black tracer) left rear spkr (black= negative)
2 x white (1 with black tracer) left front speaker
2 x grey (1 with black tracer) right front speaker
2 x purple (1 with black tracer) right rear speaker
Lower connector
1 x red ignition (switched supply)
1 x blue antenna output power (may not be not used)
1 x yellow Illumination (radio button lighting)
1 x orange permanant Battery supply
1 x black vehicle GND
If still not working swap yellow and orange wires! will not cause damage
SOURCE: What colour are the power wires, are they green &
dove è l'uscita rgb
e ingresso touch screen
devo collegare un navigatore
KW-AVX 800 EXAD
SOURCE: Hi, im searching for the stereo wiring chart for
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
