Laptop screen dead./
well first remove the huge battery first and run on AC power pack only?
if fails. make sure coin cell RTC battery is fresh.
on any PC if 2010 or older the backlamps CCFL are now dead.
use flash light on screen see data turned on, bingo for dead CCFl
your PC is at least 2008 made so CCFL are dead.
spec
Atom N450, 1.66 GHz, Single-core, 2 GB RAM, 160 GB hard drive, 10" screen
a new screen is $50 , parts + labor extra.
SOURCE: NO SCREEN DISPLAY WHEN BOOTING ON MSI MOTHERBOARD
first see pulg or correctly put
Then remove the fan and insert properly after completing then start the computer if u face again same problem i think fan is goan
SOURCE: i dont have sound drive in my system
You can download the drivers from the following website
http://tinyurl.com/dybmxo
Thanks
Proton
Kindly rate the solution
SOURCE: Using ECC ram in MSI MS-7309 board
That is correct as long as the rest of the specs match it will just disable the error checking.
SOURCE: MSI MS-7507
That board is known to MSI as 945GCM7-L, and you can download the drivers HERE.
Thanks Mark
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
