Televison & Video Logo
d
doug gerlach Posted on May 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to troubleshoot a Sharp 70" LED TV: Symptom: No Picture, not responsive to controls.
Model: Sharp LC-70C6500U At Power On: 1. Front LED power indicator is on steady, not flashing. 2. Screen is blank. 3. No Sharp Logo 4. Back light appears to be ON. 5. Every few minuites the back light will turn off and immediately turn back on. 5. Not responsive to any controls. What board do you reccomend?
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on May 10, 2018
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783195
Points
6681
Hello Doug,
I would suggest to test all the voltages in the power supply, If all the voltages test OK then It's more likely that the main board is causing the LED not to be responsive.
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Mar 16, 2008
SOURCE: No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Anonymous
  • Posted on Jan 01, 2009
SOURCE: sharp aquos lc-37d43u tv
Same problem. TV worked night before and then would turn on but no picture or sound. Power and OPC lights blinking. I couldn't change the channel or get to the menu.
I disconnected the coaxial cable and the power for a few minutes and then plugged it back in (electric) but left the cable off. I got a message that it couldn;t get a signal. At that point I was able to change the channels. I plugged the cable line back in and everything worked fine... Good luck!!!
Anonymous
  • 1077 Answers
  • Posted on Jun 03, 2009
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Aug 28, 2009
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Anonymous
  • 2777 Answers
  • Posted on Sep 28, 2010
SOURCE: Acer AL511 15" I need advice in repairing this
Ok so what is your question exactly, I do not see a question in there?
Sharp LC-46LE832U TV
Yes, it does exist!
Support Details LC-46LE832U - Sharp Electronics
www.sharpusa.com > Support
Home > Support > LC-46LE832U. LC-46LE832U AQUOS QUATTRON LED LCD TV ... Have a basic question about your Sharp product? Get started with the ...
LC-40LE832U ' LC-46LE832U ' LC-52LE832U ' LC ...
files.sharpusa.com > ForHome > LCDTVs > Manuals
PDF Consult the dealer or an experienced radio/TV technician for help. DECLARATION OF CONFORMITY: SHARP LIQUID CRYSTAL TELEVISION, MODEL LC- ...
AQUOS LC-46LE832U LED-LCD TV-LC46LE832U ' Eckley ...
www.eckleysappliance.com > Sharp-Electronics-LC46L...
On the LC-46LE832U, this technology is enhanced further with Quad Pixel Plus, which produces smoother lines by enabling the individual control of all 8-million ...
Sharp LC-46LE832U Manuals ' ManualsLib
www.manualslib.com > ... > Sharp Manuals > LCD TV
Sharp LC-46LE832U Pdf User Manuals. View online or download Sharp LC-46LE832U Operation Manual, Connection ... LIQUID CRYSTAL TELEVISION.
I have a 70" Sharp TV LC-70LE660U Serial # 501858230. It has sound but no picture. I took it apart, the backlights come on the cuts right off, do anyone know whats wrong?
The backlight is LED strips. When the television comes on the power supply senses the current draw and shuts down if it is too high. When one led on the strip burns out the current draw increases. You need to replace the LED strips or troubleshoot down to each diode and find the bad one(s)
Sharp TV has no picture. Blink code 2 plus 5
Throw away product like most modern sets
My sharp aquos LC-60E79U has no picture. Perhaps I have a backlight problem?
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2helpful
5answers
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
