First, I'm not a Frigidaire tech.
* Check your warranty. Call for service.
* Contact (note Live Chat link); https://www.frigidaire.com/Owner-Center/Contact-Us/
*** following is for information only ***
* Be sure to check the tub and filter (make sure they are seated properly.)
* Checking basic problems; https://www.youtube.com/watch?v=SXJrVGP_Ixs
* Review; https://www.youtube.com/watch?v=BbwIEU3zlG8
Aloha, ukeboy57
SOURCE: Frigidaire dehumidifier model # FDL50S1 clicking very loudly.
If the unit is not running fully, but you have this noise, sounds like the internal fan might be the culprit. Contact your manufacturer for further options.
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
