Set the paper bypass tray to the size of the check mite need to be customize measure the checks and tell the copier the size its x and y size A4 is same as letter size except its for the rest of world USA is letter and the rest is A4. A3 is 11x17.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
SOURCE: CHECK PAPER SIZE
On the front panel:
Press the down arrow twice (Tray Menu)
Press the right arrow twice (MP tray size = C5)
Press either up or down button until display reads 'MP Tray Size = A4'
Press the start/stop button. Green light shows & A4 selected
(See pp 248 - 252 of the manual)
SOURCE: konika minolta
CDC## Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
