Do airport scanners have radiation? - Computers & Internet
    Sergeant:
  • 190 Answers
Radiation from airport scanners: The dose we actually get is low. A new report has found that people absorb less radiation from airport X-ray backscatter scanner than they do while standing in line waiting for the scan itself. SE GP3 SS20 Green Plastic Sand Scoop for Treasure Hunting Review
Posted on May 09, 2018
SOURCE:
Do airport metal detectors emit radiation?
The metal detector does not expose you to ionizing radiation, e.g., x rays; neither do the wands that are used for individual screening. Metal detectors operate by generating a low-intensity magnetic field that passes from one side of the detector to the other. Bounty Hunter HEAD PL Metal Detector Headphones Review
Mar 31, 2018 | Retail Supplies
Tip
Good Way to Test Your Radio Scanner
If your Radio Scanner recieves Aircraft Frequencies and you live about 20 miles from an Airport you can look up the Frequency of the Automated Weather Beacon of the Airport which should be transmitting all the time.
on May 19, 2010 | Radio Communications
I have this scanner and it will scan but it wont pick nothin up
A couple of things could be involved in your problem. You need to be listening to the frequencies that are being used in your area, but most of them will not be transmitting all of the time. Something you can try is if you live maybe about 10-20 miles from an airport and your scanner picks up aircraft frequencies you can look up the airport and find the automated beacon frequency and tune that in. The automated beacon should be transmitting 24/7 the weather conditions of the airport.
Another thing to check is weather you have the correct antenna attached to your scanner and that it is connected properly, the circuits in your scanner may need that antenna to be connected for the circuit to function properly.
If you are using the scanner to listen to your local Fire Dispatch there can be days when there isn't anything happening.
Another problem could be that your local Dispatch has moved over to a new Digital System and your scanner isn't equipped to recieve that System.
Apr 16, 2010 | Uniden Hand Held Scanner - BC-246T 2-Way...
Antenna mounting
according to FCC rules RULE 8 - Antenna Height
{A} "Antenna" means the radiating system (for transmitting, receiving or both) and the structure holding it up (tower, pole or mast). It also means everything else attached to the radiating system and the structure.
{B} If your antenna is mounted on a hand-held portable unit, none of the following limitations apply;
{C} If your antenna is installed at a fixed location (whether receiving, transmitting or both) it must comply with EITHER one of the following:
[1] The highest point must not be more than 20 feet (6.10 meters) higher than the highest point of the building or tree on which it is mounted;
or
[2] The highest point must not be more than 60 feet (18.3 meters) above the ground.
{D} If your CB station is located near an airport, and if your antenna structure is more than 20 feet (6.10 meters) high, you may have to obey additional restrictions. The highest point of your antenna must not exceed 39.37 inches (1 meter) above the airport elevation for every 109.36 yards (100 meters, 1 hectometer) of distance from the nearest point of the nearest airport runway. Differences in ground elevation between your antenna and the airport runway may complicate this formula. If your CB station is near an airport, you may contact the nearest FCC field office for a worksheet to help you figure the maximum allowable height for your antenna.
I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
Jul 20, 2009 | Cobra MRF55 2-Way Radio
Hp6310 won't print wirelessly with apple airport
the air port is faulty.the port will be loose internally connect it properly.
its a common cause in airports.
Apr 01, 2009 | HP OfficeJet 6310 All-in-One Printer...
I tried to set up HP Photosmart C4580 printer/scanner/copier with my Airport Extreme. However it is not connecting to the Airport Extreme. Diagnostic check recommends temporariiy disabling the Mac Address...
MAC address filtering is used to prevent unauthorised people getting access to your wireless network. you need to get into the Airport Extreme configuration using Internet Explorer or any other browser, then select wireless setup then MAC address filtering. You need to turn off MAC address filtering.
Check your manual on how to configure your Airport Extreme.
Dec 02, 2008 | HP Office Equipment & Supplies
Scan function won't work with Mac OS10.5.5 & Airport
I plugged the printer cable directly to my laptop instead of trying to scan using the airport wireless router. Plugging it in did the trick.
Thank you,
Jtoussa
Nov 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MP460 problem...cannot scan
i was told that the printer needs to be directly connected to the imac (not airport) for the scanner to work.
i have the same issue w/ the airport extreme.
May 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
Computers & Internet Logo
35 people viewed this question
Ekse
Marvin
Marvin
