My Janome is a high shank 9 mm but I want to be able to use the 7 mm feet I already have.
Perhaps this will help:
https://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx?sort.ss_cat_sort=desc&index=1
If your machine has a presser foot sensor, it's likely a 7mm will not be accepted. Even if it does work, you will need to be careful to not set the stitch width wider than the 7mm will allow.
SOURCE: Janome memory craft 9000 what type shank
If you contact Janome HQ in your country, they should be able to tell you which dealer is closest to you, and the part number of the ruffler foot to suit the MC 9000......
....the technicians and questioners on this site come from all over the planet, so the where to go will depend on where you are !!
Keep it local
SOURCE: Lost Shank
Dear jujuwillow, Wed 2-11-2009 3:53am EST (USA)
RE: Elna EnVision CE20 Embroidery machine. Type 9008. Lost SHANK that holds FEET.
For USA
Dealer Locator @ http://www.elnausa.com/
For other Countries click on link below....
http://www.elna.com/index.php?country=246
Hope This Helps!
jack
SOURCE: Hello I am wondering if
Hi, it uses low shank ,but you can also use the high for high performance level..
Both works very well...
What would you be looking for adaptor for ?is yours damaged..?
You can get what ever part your looking for from the below link..
http://www.sew4less.com/browse.php
Take care..
SOURCE: Have old, (but good) 6217
You are trying to attach a long shank foot to a short shank machine. Look for a short shank foot on either Ebay. You may also find it included within a "tin" of accessories at a local thrift shop. If neither of these options work for you check with your local fabric store or sewing machine repair shop for the correct button foot.
SOURCE: Looking for compatible shanks & 1/4
try sewingpartsonline.com or Janome customer service about the parts
