SOURCE: Can't get A/C belt around pulleys on my 01 Chevy Tracker 2.5 V6
Removal & Installation
1.6L Engine
A/C Compressor Belt
To install:
Alternator Belt
To install:
Power Steering Pump Belt
To install:
SOURCE: Blade belt pullys, need diagram, picture.
Need to know what Model # you have?
Try going to www.precisionope.com and put your model number in there to see if it can give you what you need.
SOURCE: install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
SOURCE: Necchi Model 535 FA
Hi! The motor pulley may be worn and cant turn properly causing the motor to be forced so much. The result will be an instant overheating that results to belt burn too. You will need to replace the motor, pulley and the belt now to make it running. Hope this helps and have a good one!
