Https://www.youtube.com/watch?v=GW_zJur00t8
End of video mentions the CH snooze, but unsure if that will help you.
WS 9047TWC IT Wireless Forecast Station with Pressure History
SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
SOURCE: Manual for La cross technology radoi controlled digital watch #wt
Downloaded instructions and working on it.
Thank you.
Bernard W. Goering
SOURCE: THE CLOCK IS ON A
Hello. Not certain what you are trying to do with the clock, so I have attached the link to the company's list of manuals. Simply select the make and model you have, and the information should help you. Failing that, the company does have a contact page, and I am certain they will be able to assist. Good luck.
If this has helped, please rate it a four thumbs up. Thank You.
http://lacrossetechnology.com/support/manuals.php
Testimonial: "spot on, many thanks"
SOURCE: How do you change the time zone to central time on the La Crosse Technology 167-1280 clock?
Look on internet, google it. There was not your exact one but you may find one similar enough to do the trick. Companies often reuse code and procedures across products. Or try experimenting. Press or hold menu or mode key and keep on pressing until you get to what you want.
