Question about Rotary Tools & Hardware - Others
My hyper tough cordless rotary tool stopped working while sanding on highest speed what could be wrong with it
    Top Expert:
  • Rotary Master
  • 64,276 Answers
Dead battery perhaps .
Posted on May 08, 2018
4 Suggested Answers
SOURCE:
SOURCE: windshield wipers stopped working - only highest
did you ever get an answer I have the same problem. NOw my turn signals don't work and my wipers do??
Posted on Jan 05, 2010
  • 28 Answers
SOURCE: i have a rotary tool single speed chuck does not
Common issue with these, the plastic flex coupling is broken-
Replacement available for $2.57 from
http://www.searspartsdirect.com
Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
Disassembly on my model involved the following:
Remove the four Torx screws on the body, then unscrew the front end cap at the front of the tool to expose two more screws. Separate the two halves of the body to see the brittle and broken yellow coupling.
Replace with the new white coupling and reassemble. Buy spare couplings as they don't seem to last all that long.
Posted on May 19, 2010
AndrexT
  • 29164 Answers
SOURCE: I dropped my hyper tough cordless drill and it only works upside down. What do I do?
Haha, not that Super Tough then :)
Use it upside down, have it repaired or buy a new one, you broke it by misuse.
Posted on Jan 01, 2018
Jan 01, 2018 | Drills
Why did it stop working?
Depending upon its age and amount of use, the battery may no longer be fully chargeable.
Aug 22, 2015 | Dremel 8200 12V Cordless High-Performance...
I can't get the small sanding disc out of the tool.
Undo the chuck nut and then knock the spindle shaft of the sanding disc in lightly. This should release the collet's grip on the shaft. If the shaft has been pushed all the way into the chuck, remove the collets and nut and try separate the collet segments to release it from the shaft.
Aug 11, 2011 | Craftsman Single Speed Rotary Tool
Is the Dremel 400 XPR unreliable or are the users expecting to much from the tool? I like the looks of the tool but I will probably end up with a 4000. I've been using a cordless tool but it keeps...
It's heating up and tripping the internal overload. They do that to prevent the battery from overheating.
The cordless are nice but they have limited applications
Feb 23, 2011 | Dremel 400 Xpr Rotary Tool
Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
Mar 02, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Aug 27, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Cut out tool Comparison
Cut out tools are available in both cordless and corded versions. Cordless tools can be more convenient. The corded versions are slightly more powerful than cordless.
Aug 27, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Rotary tools Attachments
Flex Shaft, Sanding Disks, Polishing Pads, Metal Blades, Wire Brushes, Abrasive Brushes.
Aug 27, 2008 | Dremel Variable - Speed Multipro Rotary...
Is there a reset button for a Dremel Multi Pro?
When the brushes go on my Dremel, it just stops, sometimes erratically - no smell or burning.
May 04, 2008 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
962 people viewed this question
Top Rotary Tools & Hardware - Others Experts
MikePurcell
Level 1 Expert
Marvin
Marvin
raysaw
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
