SOURCE: turning on infared on my Canon EOS 400d DSLR
To the right of the LCD there are some small buttons. Right underneath the AV button, there's one. Press it, and you get three choices. The right most choice is self timer and wireless. Choose that option. The remote needs to be pointed towards the eye on the camera. It's on the front, on the "motor grip". And if you leave it on that setting too long, it "falls asleep", and you have to wake it up again before it'll fire remotely.
SOURCE: canon EOS 400D dslr will not work various CF
Using a flashlight, check thru the CF memory card reader if there are some pins that are bent, missing (broken) or damaged.
If this is the case, it is necessary to have serviced the camera to replace such pins, and inspectd for the broken pin pieces that may be stuck inside the camera, and cause later a short circuit.
If all the pins are in good conditions, may be the internal memory reader circuitry is failing, which requires also a professional camera repair service.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform the steps to repair it.
If so, You will need tools to do it, which includes the usage of a soldering iron, microscope (since requires micro soldering), and buy the CF memory card reader connector..
Best regards,
SOURCE: does Canon EOS Digital Rebel XTi 400D Black 10.1MP DSLR Camera work with Vista
You should not have any problems.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
