SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
SOURCE: portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
SOURCE: attempts to load then reads no disc
The problem is with the lens assembly. sometimes you may have to replace it(lens assembly) or optical pickup
SOURCE: portable dvd player says loading but wont play
This is because of the problem with the pickup unit.. Your try to clean the lens with the help of the lens cleaner, if the problem still persist then open the panel, clean and apply the white grease on the moving parts of the Disk reader.
Caution always remove the main power before open the panel.
