Televison & Video Logo
Posted on Aug 01, 2009
Panasonic DMR-EX75 has stopped receiving digital signal
My Panasonic DMR-EX75 has also stopped recieving digital signal. this problem seems to be the same as the one reported by baileytherat.
The analogue signal is fine and the digital signal received by my TV via the same antennae and cable is fine.
The signal strength shows 7.5 but the signal quality is 0. I'm located in Hampshire UK ..Software version: DVB 1.08
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1275
Points
Panasonic DMR-EX75 has stoped receiving digital signa
Anonymous
Level 1:
  • Posted on Jan 29, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1275
Points
0
My DMR EX83 stopped receiving digital tv and searching forums I thought it was probably the standard smoothing capacitor failure. After 4 months I finally ordered a capacitor repair kit (2 capacitors & instructions!) from EBay, stripped the entire machine down but could find no failed caps. I found 1 post regarding DMR-EX83 tuner problems emanating from faulty HDMI leads, disconnected mine (using only scart) & the tuner was back to normal. I then popped in a new HDMI & all is back to normal. Check yours first!
What does U81 mean
It could mean there is a fault on one of the circuit boards. See
http://www.avforums.com/threads/panasonic-dmr-ex75-85-u81-error-repaired-solved.1486954/
Auto tune will not reset DMR-EX75 which lost signal (not an antenna problem) Panasonic suggest digital tuner is faulty. I s this worth repairing? (always supposing one can find a repairer) Many thanks
Panasonic should be able to supply you with a list of agents who will repair the device. Ask for a quote when you find one, then if there is another repair shop on the list do the same. And take your choice.
1helpful
Panasonic dmr-ex75 dvd drive is faulty
Well can you please explain the problem regrading the dvd drive on your panasonic dmr-ex75?
Anyway most of the time the fault is simple like dvd drive won't get outside the tray, if this is the problem then just shutdown your panasonic dmr for 10 minutes and turn it on and check if it works. please post further comments for detailed help.
Good Luck
Regards
2helpful
DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
12helpful
2answers
2answers
Read failure o DVDs on Panasonic DMR-EX75
You need a lens cleaner to clean the lens of ur DVD recorder..
Blu-ray remote keeps triggering DVD recorder (and vice-versa)
You can "re-tune" your EX75 and its remote control by following the instructions on page 52 of the manual. This explains how to change the mode of the remote control. In short, you press the FUNCTIONS button on your remote control, get into the setup menu and select "others". The remote control entry is at the top of the list. You can change the setting from here.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
