Question about LG Dishwashers
LG Inverter Direct dishwasher shows AE and sounds like it's trying to run
Mine just needed the trap cleaned
Posted on Feb 09, 2019
    Sergeant:
    Scholar:
  • 117 Answers
The LG Support page has a Troubleshooting Guide for the AE error code and suggests it may be too much detergent being used.
Here's the link.
LG Help Library AE E1 ERROR CODE DISH WASHER LG
Posted on May 14, 2018
onthejob5130
  • 640 Answers
SOURCE: LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Posted on Feb 04, 2009
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
  • 500 Answers
SOURCE: getting an error code OE
Hi Ged Lunny,
The OE error code means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
Posted on Jun 09, 2011
SOURCE: LG true steam inverter direct drive 9 kg f1479fds5 on a screen AE error what s happend
The AE error is indicative that there is a leak somewhere in the washer and it has triggered the flood protection device found at the bottom of the machine. What you should do is find out if there is indeed a leak. Try tilting it forward and find out if water will run out. If you can see water leaking from the water, call a repairman!
Posted on Jan 31, 2017
  • 50994 Answers
SOURCE: Door on my lg inverter direct drive dishwasher does not lock
Latch could be damaged/defective
Posted on Jan 02, 2018
AE comes on. Have not used the dishwasher. Just started today. How do I stop it from coming on. I can call LG tomorrow
The AE or E1 error code indicates a possible leak from the unit. This is most often caused by excessive suds overflowing into the base of the dishwasher.
This problem could be caused by a failure on your machine or the detergent used. I highly recommend you follow the troubleshooting from the LG website. HEre is the link.
Jun 28, 2018 | LG Dishwashers
Jan 31, 2017 | LG Washing Machines
E1 message on my LG Inverter Direct Drive Dishwasher
An F1 usually means a communication error between the control board/touchpad and the motor/pump assy. Could you please supply the full model # for your unit?
Mar 12, 2014 | LG Dishwashers
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
1,728 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
