Question about Yes Televison & Video
My xfinity remote has died and I cannot change channels on the bravia tv. there are not buttons on the tv I can find and yes can turn it off using the xbox
SOURCE:
SOURCE: MY REMOTE WILL NOT CHANGE CHANNELS ONLY TURNS TV ON OR OFF
After much trial and error, we discovered a temporary fix. We taped a 3 x 5 index card to the front of the box directly to the right of the time/ channel number. The remote will change both the channels and the sound level with this "fix." Could there be some kind of emission coming from the box that interferes with the remote? Maybe Motorola could put a more opaque front on the box.
ympm
Posted on Jan 22, 2009
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
SOURCE: Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Posted on Oct 25, 2009
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
hoodpeter
SOURCE: YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Posted on May 03, 2012
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
Apr 26, 2017 | Televison & Video
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
Sony bravia tv constantly changing channels
Is the tv new or has it started to do this recently ?
Try to eliminate the obvious.
Does the remote continue to flash when you release all of the buttons? Is it a stuck button ?
If you cant' see the remote output, try using your smartphone camera. Most phone cameras will capture infrared light ( invisible to the eye). Aim the remote at the camera and see if you can see the flashing light, which is data being sent to the tv. When you release the buttons does the flashing stop ? If so remote is ok
Next turn all of the lights off in the room with the tv. Also turn off any lights that may shine in from other rooms. Try using the remote
If your tv functions normally, you may be getting interference from your lighting. Some LED and CFC fluorescent lights flicker at a rate which may be close to the remote IR output frequency.
If turning off the lights fixes the issue, turn on each light to isolate the issue. Replace the bulbs with ones from different manufacturers.
Let me know
Oct 24, 2017 | Sony Bravia KDL-26V4000 26 in. HDTV-Ready...
I can't get my xfinity remote to work on my new Sony Bravia tv.
Call Xfinity to get another Digital HD DVR mine is a RGN200N it has a programmable remote you can program 3 devices using the codes provided in the guide. Does the box that remote controls offer HD? Or just digital TV?
Nov 10, 2012 | Televison & Video
Can not change the channels on my Sony Bravia KDL-46V3000. The remote will turn the TV on and off but will not change the channel.
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Sep 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
REMOTE WILL N0T CHANGE CHANNEL? HOW TO FIX?
Does remote change volume level or can open Menu in TV?
If yes, then its specifically channels buttons that do not work in remote and new remote would work.
Sep 05, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV volume goes down with out being touched
may have a sticky button or a shorted transistor switch.
Jul 01, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Televison & Video Logo
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
