SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
SOURCE: We are searching for a schematic for a Legend electric golf cart
THE BATTERIES ARE RUN IN SERIES THAT MEANS THAT THE WIRES GO POS. TO NEG. NEG. TO POS. STARTING IN THE BACK AND THEY RUN LIKE THIS TILL YOU GET TO THE OUTPUT FROM BATTERIES TO MOTORS THE CURRENT GOES IN ONE SIDE OF BATTERY AND OUT THE OTHER BY CONECTING ALL POSITIVES YOU MAY HAVE JUST KILLED THE BATTERIES
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
