And when I type admin which was its default password, it says wrong password. I have never changed the default password and I tried so many other passwords, but none worked. How can I factory reset the machine or is there any other solution? Please Help
SOURCE: Dell Wireless 2350 Router
Connect one of the router's LAN ports to the computer, no other connections to the router.
Reset the router to factory defaults by holding the reset for 15 seconds with power on.
Reboot the computer.
Start, Run, cmd /k ipconfig
The address of the Default Gateway is the base address of the router, type that into IE to access the setup pages.
SOURCE: how to reset VSX 8000 to factory default - Forgot the password
RTFM!!!
section 8, page 4
System -> Diagnostics -> Reset system
you will need serial number for this
good luck.
SOURCE: When I enter "http://192.168.0.1" it's asking me username and pas
hi
for the username use administrator and ofcourse the password that u have set
cheers
pls rate if it was any help
SOURCE: I have just purchased a
Hello, usually the default for this type of router is;
the default username is Administrator (case sensitive).
the default password is blank.
Be sure to type the user name with an capital 'A'
:) Hope this helps!
