SOURCE: SET UP VIERA LINK PANASONIC PT960
The first question you need to answer would be, "Does your TV support Viera Link?" Most newer Panasonic TVs and other A/V devices support it, but it's hit or miss (usually miss) with other brands. I know Onkyo is one brand that has stepped up and offered Viera Link support on some of its devices, but I'm not sure about others. If your LG brand TV doesn't support Viera Link, you are out of luck and you'll have to rely on seperate remotes for the TV and home theater. If your TV does support Viera Link, the next question would be, "Are you using HDMI to connect the devices?" Viera Link can only communicate over HDMI (not component video, S-video, coaxial, composite, digital optical audio, etc.) If either of the aforementioned questions were answered "no", you can still connect your devices and use them normally, but you won't get the benefit of Viera Link communication between the devices. In that case you will likely have to keep using separate remotes.
SOURCE: I have the panasonic SA-PT960.W1 keeps flashing
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
SOURCE: I have a Panasonic SA-PT960 surround sound/dvd
Hi! the chgr err code indicates one of you trays is stuck inside the dvd tray unit. this occurs typically when the reader is initializing the last disk viewed and you push the exchange disk button. This happened already twice on my system. I did solve the problem by opening the unit and removing all components until I could access the trays and manually release the mechanism. I only recommend doing so if the player is out of warranty and if you are not afraid on working with small electronic/ components parts. I could not find any other non-invasive solution to the problem.
what did u do? I have the same problem and I am hoping that I can still keep the speakers and replace the DVD. I called Panasonic and they said I shld take it to the nearest service center and they said no replacement. I dont want to buy a whole new system, what did u do?
Press and hold [?] (Stop) on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again.
All settings should return to the default values.
Not saying it will work though!
Not
