It was working fine until all of a sudden it stopped. All of the connections, including power, are good. When I depress any of the line buttons, I don't even get a dial tone.
SOURCE: message center of GE Phone Mod. No. 29897GE1-A by ATLINKS USA,Inc
I wish I had a solution for you. My Uncle has the same problem and the manual instructs to unplug/replug the machine and then reset the date and time. He has done that for a while and now even that isn't fixing the problem. I find this to be highly unacceptable. I'm planning to get him another phone that WON'T be GE.
SOURCE: Headset has static
Perform a reset on the headset. Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times. Release both the mute button and the call answer button. See if it works now. If it doesn't, try a re-subscription (should be available in the manual).
SOURCE: I have a old phone, ATLINKS USA, INC, model #:
I have an Atlinks Cordless Phone Model # 21028CE3-A and I would like to know how I can purchase a new add on to the cordless. My phone works fine but I need a new phone for the cordless in the other room. My phone will not record the number when trying to make a phone call on it. Or do I need to purchase a whole new unit?
SOURCE: Atlinks USA model 25951EE3-A records messages but
Place the handset in the Base station - NOT the Remote Charger. Wait 10 seconds for the phone to bond with the base station. The display will go on and off twice. Remove and you are on the way. Toy can do this for up to 4 phones I believe.
You will have to do this every time the the lights flicker or go out.
Also, press Menu on the Handset and use the + and - Keys at top to navigate through menu. Use the * key to exit.
TIP: If the lights quickly go off and on and the Answerer seems to be fouled up. Unplug the Base station for 10 seconds and plug it back in. All will be well again.You will have to re-bond the remote phones.
