Question about Kitchen Ranges
Any suggestions where i might find a discontinued gas valve assembly part 86298 for a model RSG 305
The left front burner had to be shut off because of gas leak. The repair man says it needs to be replaced but the company discontinued manufacture years ago.
    Top Expert:
  • Kitchen Ranges Master
  • 52,389 Answers
Fixya is unable to suggest sources for the discontinued gas valve.
Posted on May 05, 2018
SOURCE:
  • 1314 Answers
SOURCE: Jenn Air gas cooktop
pop me an email at b4829@yahoo.com and reference your cook top you can rate me later
Posted on Mar 30, 2008
  • 116 Answers
SOURCE: Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Posted on Aug 26, 2009
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
SOURCE: Breadman TR2200C Ultimate Bread Maker pan leak
I was finally able to find a same size of heavy duty shaft seal from McMaster-Carr and installed on the pan with liquid weld after greased its inside. I put an extra washer on the shaft as well since the shaft itself was worn a little and wobbled . I needed a new snap ring to secure the spindle in place. Old one was rusted and disappeared.
Our bread machine is now back to work and we enjoy having a tasty bread every morning again.
Posted on Nov 01, 2009
SOURCE: burner lights but will not shut off. then pressure
i am having the same problem with mine changed the pressure relief valve and the ECO \ TSTAT but still gets extremely hot can't even touch the water what else could it be
Posted on May 02, 2010
How remove a pilot generator from a minimax ch 200m
shut off gas supply. undo gas line union. remove wiring from gas valve. undo burner tray support screws. slide burner tray out. remove pilot generator leads from gas valve. pull out pilot generator from pilot assembly. then re assemble
Aug 17, 2014 | Pool & Spa
Gas Control Valve replacing!
Shut off the water and gas to the heater. Drain the heater. Disassemble the gas line to the heater starting at the Union and working to the gas control. Disconnect thermocouple, burner and pilot tunes from the bottom of the old gas control. The old control will screw out of the front of the heater. Grab the entire housing of the control and twist counterclockwise to remove. Perform new gas control install and connections in reverse. Remember to apply at least 4 wraps of Teflon tape on all threads before assembly. (Teflon paste may be used) Do NOT put any sealant on the thermocouple,burner tube or pilot tube connections (these are compression connections, make them fairly snug.) upon completion, fill heater, turn gas back on relite and check for water or gas leaks
Jan 03, 2014 | Rheem 42VP75FW 75 Gallon Natural Gas Water...
Need discontinued burner valve for GCV36G
You can try an appliance parts supplier. There might be a crossover to a current part
May 08, 2013 | Thermador Kitchen Ranges
Maytag LP Gas burner problem
are you sure the pin in the gas pressure regulator under the plastic cap and brass nut was turned 180 degrees to set it for propane gas?
Aug 20, 2012 | Maytag Dryers
Brinkmann Pro Series 2545 Assembly - The side burner valve nozzle does not fit firnly into the burner venturi. The venturi (pipe) is about 1 inch too short!
When you attached the side burner assembly to the grill frame, did you pull it forward before tightening the 4 bolts that hold it in place? If not this could account for part of the problem. The other would be how you routed the gas line hose from the 'Y' connector, to the side burner connection. If routed differently than what the assembly instructions indicate, you would come up short on the length.
In any event, your model grill has been discontinued by Brinkmann, but the warranty and some parts are still supported by the manufacturer. I'm assuming you just purchased this grill and are in the process of assembling it according to the Owners Manual. So, if you continue to have a problem contact Brinkmann's Customer Support Hotline 800-527-0717.
Hope this helped you. Please let me know. Thanks.
May 14, 2011 | Brinkmann ProSeries 810-6330-W Grill
Hello, My Kenmore 70 serie (model 110.72712101), will not heat up. Cleaned filter and exhaust vent. Any suggestions will be of great help. Thanks!
The ignitor is probably bad not aloowing the gas valve to come on and ignite the gas to heat the dryer. The ignitor is a flat bimetallic element that heats up when the dryer is turned on to light the burner to heat the dryer. It is usually located in the lower left section of the dryer near the burner assembly. It has two wires usually white going to it with a plug in connector on the end.
Jan 18, 2010 | Kenmore 73952 Gas Dryer
My Kenmore gas dryer runs but it does not dry.
Obviously make sure the gas supply valve is open and gas is going to the unit.
Then determine if the burner is lighting at all... there is a small plastic plug in the lower left of the front panel. If you remove this plug you can see the burner assembly.
When the drier powers up you should see a glow plug that gets red hot, then a click (the solenoid opening) then the burner should light and you should see a blue flame.
If this does not happen, the glow plug will go out and then in a minute or so, the process will start again with the glow plug and the click.
If this cycle repeats without ANY lighting of the burner, you need to replace the burner assembly and/or safety valve... send the model number and I'll show you the parts.
If the burner lights for a few seconds and then extinguishes, it is probably a faulty flame sensor, which is a probe extending into the path of the burner flame about in the middle of the burner assembly (It makes sure the flame is lit and if it doesn't get hot enough it closes the gas valve to avoid filling your laundry area with gas). You can try cleaning it, and then replacing it. Again if you give me the model # I can help you...
Oct 11, 2009 | Kenmore Dryers
Had no gas coming into the oven of my Viking 305. bought a new dual thermal valve and replaced it. now i have small flame on left burner and none on right. right after installation, flame was strong for...
Are the burners on top getting enough gas? Is there enough gas coming out of the wall? Did you purchase the correct dual valve? Is the orifice sizing correct? Make sure the holes are not plugged on the burners. And u should also check to see if your line has debris in it. Either unplug the holes or check the pressure out of the line in the wall. What makes you think the right one isn't getting enough gas? Could it be an ignitor? Anyways, the burners have a 5 yr warranty. Try replacing those. Good luck.
Apr 28, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Frigidaire electric range left front burner
make sure the knob isnt just worn and spinning on the gas valve shaft.if thats not the case the vavle internal parts are most likley worn,you can rebuild them or just replace the valve itself.
Aug 14, 2007 | Frigidaire fes365e Electric Kitchen Range
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
