The printed out figures blurred and not clear
SOURCE: possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
SOURCE: Not printing...printer says remove or change ribbon
First you want to clean both the cartridges and the cartridge seats inside of the printer with warm water and a soft cloth (I use old t-shirts). After you've done that place the cartridges back into the printer and clean the printheads. You can do this by following the steps on page 83 of your user manual:
1) Load the paper
2) Press "Copy"
3) Press Options until Maintenance appears on the display.
4) Press the right arrow until Clean Cartridges appears on the
display.
5) Press Select. A nozzle page prints, forcing ink through the
nozzles to clean the clogged nozzles.
6) Print your document again to verify that your print quality has
improved.
You can also find information on cleaning the cartridges on pages 83 and 84 of your manual. If you don't have one available, you can download one at:
http://www.lexmark.com/publications/pdfs/x6100/eng/ug.pdf
I hope this helps!
SOURCE: How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
