Question about HP Photosmart D7160 InkJet Printer
Ink sys failure error message
HP Photosmart d7360 been working well til now. Got error msg re ink sys failure. Followed prompts to shut down and reboot; no change' then shut down, pulled all ink cartridges, waited 2 mins and tried again. No change, same error alert.
What to do next???
Thanks fo any ideas...
  • 26 Answers
Try the following steps and check if it resolves the above error.
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
Wish
Posted on Aug 01, 2009
SOURCE:
HP Photosmart D7360 ink system has failed. How do I fix this?
with 2 new cartridges installed, shut the machine off and back on again.
Jan 06, 2015 | HP Photosmart D7360 Digital Photo Inkjet...
Photosmart 7360-ink Ink System Failure error
1) Press * and # at the same time
2) Press 1, 2, 3 and “support R0632M” should display
3) Press > and “information menu” should display
4) Press > and “configuration menu” should display
5) Press OK and “hardware failure status” should display
6) Press OK “failure status: clear”. Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, and plug cord back in then turn printer back on.
And Thanks.
Mar 11, 2010 | Office Equipment & Supplies
How do you take the right side off a HP D7360?
Follow the steps below to resolve this issue.
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.If the error codes still display on the front panel, service the printer.
Dec 29, 2009 | HP Photosmart D7360 All-In-One InkJet...
Error 0xc18a0206 On the HP Photosmart D7360
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Apr 03, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Dec 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
have you unpluged it from the outlet? can you see any paper stuck?
otherwise you have a bad system board and would cost more to fix than just to by a new one.
Sep 02, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart D7160 InkJet Printer Logo
415 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
