SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
SOURCE: UNLOCK CODE FOR SV2000 WD806 DVD PLAYER/VCR COMBO
hi
paragtm
search all over no luck yet will keep trying for you
in the mean time look here some good links that may help you out in the first few post .
riz.
SOURCE: unlock code to unlock dvd player to play dvds from all regions
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
make sure you have the disc draw open and enter the above code via your remote.
let me know if it works
SOURCE: Want to unlock my lgV692WK dvd vhs combo player
1. Turn on dvd without disk
2. Press pause
3. Type 314159 wait for menu to apper
4. Press 0
5. press pause
6. Turn off for 10 sec then back on
7. Regionfree!!
Jay
SOURCE: Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code-
free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
