SOURCE: pre set stations
Here's a link to the manual download page at Alpine. It should tell you everything you need to know.
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=CDM-7835
SOURCE: 2002 Dodge Caravan se radio problem
Does it have RADIO Controls on Steering Wheel? If so does the Air bag light EVER come on While Driving down the road. If no to these Questions.
I dont like at all being the Bearer of BAD news
I am Not Exactly A "RADIO" Expert But I have seen this Before and My Repair for it was Replacement.It is My Thought and Thery that somehow the MEMORY Cuircit gets Burned out adn in turn the On Off Cuircit is also Effected by this, Hoping this is of Good Help to you., RejakWilson
SOURCE: how to pre-set radio stations panasonic radio/cd/tape recorder
the best thing would to go to the panasonic web site and they should have the solution. they might even have the manual for it. without a picture this is the best i can do.
SOURCE: I can`t listen the radio station
Hi,could be low volume level.You can increase it with the button on the side.If no joy try use other earpiece,if nothing again then there's a device fault. You can try reflash firmware using Nokia PC Suite-Firmware updater.If after that not working then go to Nokia centre,if under warranty repair is free of charge.
Rate me if helped.Thanks.
