SOURCE: images too dark or too bright
Metering has gone on the .Can you set the camera to Aperture priority or speed priority?Set to either permanently if you cane then you should get a standard exposure. The inside shots may appear dark, but all the information is there and a treak in an image editor will brighten them up. Cant do the same for too bright images though if they burnout then that's it. a repair is not likely got a birthday any time soon Got some one that luvs you enough to buy you the next one.?
SOURCE: IRIS STOPPED WORKING DARK INSSIDE AND FINE OUTSIDE WHEN FILMING CAN ANYBODY HELP?
Firstly with some thick cloth around it and with it switched on, give it a good bash with a rubber handled pair of pliers or something (looking from behind) on the right hand side corner near the mics.
the iris gets oil/grease from the zoom on it which makes the iris stick,
if your lucky a hard slap will free it but if not it will merely change its position and make the picture brighter or dimmer
for a full solution see my article
http://zyvid.com/smf/index.php?topic=449.0
SOURCE: can the bunker hill security color security camera
95914 is : Green is voltage (12vdc), yellow is video, black is common ground to voltage source and camera-to-monitor, white is audio.
SOURCE: cut wires on bunkhill weatherproof security camera#95914
My bunker hill has a black, white, yellow and green. I am confused with the white. Help
