SOURCE: Screen goes off after every 2 secs. Pls help
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: L17AMTN 17 in. Flat Panel LCD Monitor: monitor starts. shutts off after 10 secs. displa...
It is telling you that it is not getting he signal from your video card, so please check to make sure the VGA cable and all the pins at both end of the connectors are OK, try reseating the video card. Try this monitor with other PC. We need to narrow down the problem. Please post back what you find.
http://s807.photobucket.com/home/budm/allalbums
SOURCE: Nokia 2630 .The problem is White screen for 2-3
1. Check the battery. They may be worn out and dead.
2. Next time, your screen goes blank / white, shut off the mobile voluntarily, restart the phone and press reset button.
3. This will fix the problem. Caution: You may lose all your data.
SOURCE: SANYO DS31820 POWERS UP FOR
Hello, Unless the power supply is a separate board it is not available by itself. Looking a a partial parts list, there seems to be one main board inside this TV. The part number is 610 300 2125 and the price is 430 dollars(seems to be available from www.partstore.com). Your best bet is to locate the defective components in the power supply circuit or get the TV inspected by a qualified tech.
SOURCE: sanyo ds31820 tv powers up 5 sec's with audio/
Considering the fact that this set is rather old, you will not be able to find a power supply online. You can contact Sanyo to find out if they source the part. Contanumber for parts sales is : (800) 877-5036 Ext. 1485
