SOURCE: Hi I have LOFRA
There's one being auctioned (ends Fri 14th) that might be ideal for spares http://tinyurl.com/2drkcg5
Hope this helps
SOURCE: I love my Lofra gas
Hi, you can get the user manual to your Lofra Gas Hob here. Click on this LINK.........
SOURCE: Lofra LEF9EGP electric oven stopped working - fuse?
You probably had the heating element burn out. Disconnect it and test for continuity. If open, replace it.
murf427
It's possible to lock the selected functions by keeping the "Key" button pressed . An acoustic
and flashing warning will activate whenever any changes to programmed function are tried to be
made. By activating this function it's possible to switch the Electronic Module off while the
function controls remain active. To deactivate the lock keep the "Key" button pressed a second
time.
If you still have your owners manual look up child lock. If you do not have a manual and the oven door is unlocked I really need a model number.
Thanks,
Kelly
