Question about Pride Health & Beauty
How do I take off the rear tire of a Pride Victory 10 scooter and putting a new tire on?
    Top Expert:
  • Pride Master
  • 61,847 Answers
SOURCE:
  • 118 Answers
SOURCE: Pride victory mobility scooter
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
Posted on Nov 27, 2008
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 175 Answers
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
Posted on Jul 07, 2009
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
  • 25 Answers
SOURCE: I have a pride Victory 4 wheel scooter. Ran great
possibly burnt one of the motor brushes, you can remove the brush, and clean the face of the brush or put new brushes in
Posted on Sep 15, 2009
I have a Victory three electric scooter and it will not go forwards but does go in reverse just fine. Could you tell me what and how to check it to find the problem?
Hi , if the scooter goes into reverse okay , it could a be throttle issue , or the forward logic( mosfet out put ) of the PG Drives controller has failed...
I offer free testing if based you're in the UK...
Regards
www.gewizrepairs.co.uk
Jan 20, 2015 | Pride Mobility Products Pride Victory 10 -...
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
1997 PRIDE VICTORY GIVEN TO ME, BUT NEEDED FRESH BATTERIES PURCHASED NEW BATTERIES INSTALLED THE KEY, LITES & HORN WORK BUT UNIT WILL NOT MOVE FORWARD AND/OR BACK
check the freewheel lever on th rear of the chair near the right rear wheel if you can push the scooter easily then you are in freewheel locate the lever and move it to the drive mode and try to drive the scooter again if it still won't move then you have other problems that can only be checked by a service tech Hope this helps
Feb 26, 2011 | Pride Mobility Products Pride Mobility...
Pride victory 10 clicks while going foward
If the click is coming from one side of the rear of the scooter, I would think you have a dry axle. If this is the case, you will hear a regular clicking noise, just as if there is a stone in the tyre. All you have to do is remove the wheel, apply some grease to the axle and re-fit the wheel again. When removing the wheel, be careful not to loose the hub key (usually a small strip of square metal that fits in a groove in the axle and wheel). This clicking noise is a very common problem with Pride scooters and one we regularly deal with, even on brand new scooters. If this doesnt cure your problem there are a number of other things it could be, but i would need more specific details to try and help you. Hopefully its just the axle! Hope I have been of some help to you.
Mar 22, 2010 | Pride Mobility Products Pride Victory 10 -...
Air preassure in victory scooter
Most electric mobility scooters with inflatable tires require a tire pressure of 30-35 psi (be sure to check the manual of your scooter for the correct tire pressure). Do not allow the tires to become under-inflated or over-inflated. Under-inflated tires could make the scooter unstable and over-inflated tires can burst under pressure. Also, you should manually inspect the tires periodically to make sure they haven't taken any serious damage that could lead to a flat.
Jun 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
52 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
