SOURCE: dvd won,t eject
This is going to require opening the unit and taking the DVD unit covers off. If you feel confident and are good with tools and have a good memory (to remember how it all goes back together), you should be able to get the DVDs out. Just remember to be careful inside the unit, go slow and don't force anything. After the DVDs are out and you have the unit back together properly it should be OK if no damage was done to the laser assembly. Good luck.
SOURCE: DVDS stuck in overhead DVD player
the motor will not be strong enough to eject. you can try the emergency eject hole with a paper clip . just push straight in and the gears will began to turn so push straight in a couple of times and it should began to eject.
SOURCE: Wireless head phones won't communicate with our Rosen A10 system
1 of 3 things can cause this
1) the unit needs to have volume turned up by its remote.
2) the volume needs to be turned up on the wireless headphones (locate on ear piece looks like a roll dial) power is on one side of headset volume is usually on the other side of headset.
3) the wireless headphones are faulty and should be replaced by company
note: sometimes the all in one units don't come with a remote which is needed to adjust some features if there is a vol button on DVD unit turn it up if not the other 3 should solve this problem
hope this helped
SOURCE: cant find headphone socket for rosen in-car dvd player
As far as i know, all Rosen in-car dvd players come with IR (infra-red) headphones so the sound is transmitted that way rather than using a lead from the headphones to the unit, therfore no sockets are neccessary!
Hope this helps....
