SOURCE: husquvarna Viking Rose thread error
You need to see if the take up spring is moving freely when you are in these first 15 minutes (I assume the machine runs ok after 15 mins).
The take up spring is on the left side of the tension assy. When the thread is pulled up toward the take up lever, you should be able to look through the slot in the front of the machine and see a copper colored wire move up and down as the thread is pulled and released. This is the end of the take up spring. The spring is attached to the thread breakage sensor. If its movement is sluggish, it may cause the machine to falsely indicate the thread broke.
Sewing very slowly may cause this problem to stop. If the machine runs as minimal speed and then gives thread break indication when speeding up, the sensor interrupter is not moving fast enough and should be cleaned and lubed.
SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
SOURCE: bobbin thread breaks. sounds like clicking while sewing
hi there,
pls, the see the figure how bobbibs thread directionhave you seen theres a screw on latch body case of bobins,you can adjust this but mostly this is factory
adjusted,bobbin tension can adjust here.but try to follow the thread direction.set up again the dial setup tension to #3 and stitch to #8 to #12.bobbins slip due to accumulation of thread under
bobbins.hopefully this may help you to continue sewing.
have a nice day,
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
