Been having problems lately with my WTX not picking up satellites, switching itself off while playing and also not automatically picking up the next hole,
SOURCE: unit automatically switches off
Maybe all you need is to dust off the DVD player's pickup. I have had this happen several times with several players. After dusting the pickup, those players are still in service.
SOURCE: ON/OFF SWITCH
It sounds like a bad connection with batteries or battery holder or a loose cable somewhere within the camera. Maybe even a dry solder joint or intermittent fault with the power switch. Unless you know your way around the innards of your camera I'd recommend a qualified tech to take a look. BMW
SOURCE: Only picking up one satellite
Thank you for the info.
Here is what you can try:
Try to get the Echo 8.10(110W) first by connecting the LNB on your left if you are behind the dish. On the first transponder from 110W you need to get anything better than 90% quality.
After this is done you may have to play with the skew until you get 119W. On 119W the first transponder frequency is 12239Mhz.
The skew will depend on where you live.
Check here for more info on the parameters to get your dish align.
BTW, What kind of receiver do you have?
SOURCE: Problem with SHARP AQUOS LCD TV - LC32GA6E: It switches on by itself!
Is the remote in the room and pointed at the tv when this happens? If it is try fresh batteries in the remote.
SOURCE: Nokia 3100 automatically switches off while texting.
my 3100 is switches off while iam taking images & coundn't show the network coverage.
