These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Testimonial: "You answer is no help cos the link has no hisense"
SOURCE: I have a hisense 40 inch tv model number 50k23dg that the light blinks 8 times and don't tern on
Any more than 5 blinks are problems on the main board. It indicates a failure during P.O.S.T. (power on self test) This problem is a "fatal error" and cannot be reset, the board is indicating a fault on the board itself.
