My nephew pulled the wires off the three switches. Power on,roller on and the third, Need wiring diagram to ensure I reconnect the wires correctly.
SOURCE: Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
SOURCE: Intel E139761 or AA 732604 Motherboard wiring diagram
http://www.cs.unc.edu/~jeffay/dirt/FAQ/DELL410_ServiceManual.pdf
Seems you have a Dell computer. Is this manual the right one?
SOURCE: roller not turning - dyson DC25
I had the same problem. I found that pushing the button next to the power button fixed it.
SOURCE: which color wires connect to pull chain switch
do you have a Menards, or a Lowes in your area, if you do they can give you the answer to this question, it is a bad idea to get this information from on line unless you go to the website for the fan and see if they have the correct wireing diagram on their website......
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
