SOURCE: Our Ricoh MP 171 devices go offline after one
have you tried doing a local connect using a crossover cable to the printer to see if it is the printer or the 2k3 server?
I have seen this issue when terminal services are enabled on the server.
if when you connect locally to the device using x-over it still does it it may need to have the nib firmware updated, however if it doesnt I would run a packet sniffer on the network jack that the device is plugged into and check to make sure that the port is good and transmitting and receiving all packets check the network cable and replace that and if all else fails try the device on a different network port.
SOURCE: where is the waste toner
Right inside the front cover. Open the cover, and the plastic part just under the area where you install the the toner is the wast toner bottle. Press the two release tabs on the top and pull towards you.
SOURCE: Ricoh mp c2550 has sc440-02
Welcome to Fixya. That code is color drum motor lock. Pull each drum unit out and look at the drum surface if one is not turning good it will have toner all over it. Could be that the drum is full of waste toner, but usually it is a backed up waste toner auger system. If that machine uses a fuser oil the oil has leaked down into the waste toner auger system and clogged it up.
If you have questions please let me know. Thanks for using Fixya.
SOURCE: Ricoh MP 4000 reset to
You can reset admin password when you open sp mode with login supervisor (no password)
SOURCE: Error sc 565 mp c2030
Hi
The first thing I tend to do with any fault on a computer or related hardware, is to turn it off, unplug it from the power supply, turn off and unplug the rest of the system components. Wait for a few minutes, plug the equipment back in and turn all components on and then reboot the computer. After this I start to look elsewhere for fault diagnosis and repair.
In your case I found a list of codes for your machine here:
Error Codes Ricoh Aficio MPC2030
Here you can view the specific codes by using the drop down menu in the middle of the page. You can also change the make & model of machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
