Home Logo
E
Elliott Sirota Posted on May 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have American Standard Absolute whirlpool jacuzzi. It won't run, when I plug it in, it pops the breaker. UltraJet 2 speed pump Emerson 2 H.P 115v, 60-1. Could there be a reset on the motor itself?
The Air switch connection was loose.
Steve Pack
Level 3:
  • American Sta... Master 7,121 Answers
  • Posted on May 02, 2018
Steve Pack
Level 3:
Answers
7121
Questions
Helped
2271769
Points
27886
No reset on motor ( that would not cause breaker to trip, suspect heating element, or motor is bad.
Testimonial: "Thanks, the air switch connection was loose"
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jan 14, 2009
SOURCE: Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Anonymous
  • 62 Answers
  • Posted on Jun 05, 2009
SOURCE: We have an American Standard lifetime whirlpool
Chances are that the drain assembly was not part of the tub but a 'generic' plumbing part. Is this pop up drain the type that you push down and it clicks closed and push down and then it pops up? It unscrews from the drain fitting and you can get a replacement at a big box store. A better pop up replacement is one called a Rapid-fit. It drains faster.
Alan
  • 80 Answers
  • Posted on Sep 05, 2009
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Anonymous
  • 119 Answers
  • Posted on Nov 15, 2009
SOURCE: My American Standard Whirlpool does not turn on.
Remove access panel make sure pump is plugged in some electricians put a GFI outlet under tub for motor make sure GFI did not trip. Next the switch is an air switch look for the hose going to switch is connected last you may need a new air switch which is common to fail
Coastsider
Charles East
  • 331 Answers
  • Posted on Apr 14, 2010
SOURCE: Whirlpool Pump - Hums, no water flow...
The impeller and/or motor shaft is stuck or seized. If accessible you can try rotating the motor shaft with a visegrip plier or similar tool to see if it will come lose. Otherwise you should consider having the pump taken out and overhauled. Often the shaft seal begins leaking and result in water damage to the motor bearings. Bearings can be replaced, but compare labor and parts for overhaul to simply replacing the whole pump.
1helpful
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
1helpful
3answers
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
On our 6250 Generator, the breaker pops continually. This happens when running only lights on our RV, or when using it to run a water pump. It will run just fine and then the sound changes and the...
You will have more available power (and use a different larger breaker already on your generator) if you use the 220 plug instead of the 115v plugs. Have an electrician make you an breakout box separating the 220v plug into two 115v outlets. Or your can replace the push button breakers with better quality 25 amp. Problem is that the 115v receptacles are probably 15 amp. Other solution is to try a 220v pump instead of 115v (more efficient draws less amps). Good luck
What kinda breaker do i need for an american standard jacuzzi with 125 btus
If you are talking about an electric water heater the breaker would be determined by the wire size and the voltage draw of the water heater. The heater instruction should have this information and recommendations.
Feb 06, 2011 • Home
Jacuzzi pump wont start. Runs well when i help it.
sounds like a bad capacitor or a bad spot on the motor. either way you will need a new pump.
couple of sources for bath pumps for you.
Bath Parts Plus
US Parts Center
High speed on pump motor just hums then trips breaker. low speed works fine.
possibly trying to draw more power than the breaker and wiring are rated for.. check maximum amperage draw from motor, then check breaker.
If breaker is rated lower than High speed amperage draw, then have a qualified electrician install proper size of wiring and breaker.
If not, then the high speed coil of motor may be defective, check for warranty of unit.
2answers
My american standard jacuzzi tub is pluged in but jets won't turn on
check for power at plug in if power your vacume switch is probably out replace switch.
1helpful
Rapid Heater for Jacuzzi
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Magnum Force Jacuzzi Pump stopped working
No serviced by pool technician. But you can look in your breaker box for a popped breaker, it should be 20 amp and be positioned in the middle instead of on or off position. Kirk
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
