Ramona Gonzalez Posted on May 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I replace the image transfer belt unit on a bizhub 203 does it have to be reset?
Adorjani Laszlo
Level 3:
  • Konica Minolta Master 1,316 Answers
  • Posted on Mar 31, 2019
Adorjani Laszlo
Level 3:
Answers
1316
Questions
Helped
457403
Points
2563
No,the transfer belt unit resetting automatically.
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Jun 19, 2008
SOURCE: transfer unit on bizhub C250
its not so hard, open side door, remove 2 screws, and pull out the transfer unit gently. and reinstall new TBU. BE VERY CAREFUL WITH NEW UNIT, DO NOT DAMAGE IT.
Anonymous
  • 12 Answers
  • Posted on Apr 06, 2009
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Anonymous
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Bizhubman
Ben
  • 108 Answers
  • Posted on May 17, 2010
SOURCE: how to reset the transfer unit (fuse?), do you
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
Ty Schmidt
  • 118 Answers
  • Posted on Oct 31, 2011
SOURCE: how to reset image unit for C350 bizhub?
well there is a chip on the image unit that image unit (all colors) you need special chip writer to reset. you may need to just buy a new unit or drop me a line i may be able to get one...
Konica Minolta bizhub C252 cannot stabilize
Clean IDC sensors that read toner density on transfer belt.
And do Image stabilise reset.
If that doesn't help then:
If Imaging units are over life -replace them if Transfer belt is over life replace it.
2answers
KM bizhub c 203 prints blank on yellow, I have tried replacing the y imaging unit, y laser unit, image transfer belt, all to no avail. How could it be fixed?
Have you tried the High Voltage board that supply the voltage to the print heads and ITB. could be the print head is fine biut not getting any power to fire the laser and write to the drum
After replaced transfer belt unit its error 2152
Open close front door. to reset. Ensure belt was install properly the code is for that device also check the transfer roller sponge one. ensure shipping parts remove before installation.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Cual es la cinta de transferencia que tengo que quitar para limpiar los sensores de control de densidad de una bizhub 203
replace the black image unit and clean the transfer belt sensors located under the transfer belt
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
2answers
Machine status P-9 what is this message?
Black Imaging Unit failure
• All density readings taken from the density pattern produced
on the Transfer Belt are 0.5 g/m2 (IDC Sensor
photoreceiver output) or less during max. density
adjustment (Vg/Vdc adjustment).
on the Transfer Belt are 4.5 g/m2 (IDC Sensor
Photoreceiver output) or more during max. density
adjustment (Vg/Vdc adjustment.)
Remove and reset the Black Image Unit. If this doesn't help the Image Unit may need to be replaced.
2helpful
2answers
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
1helpful
2answers
I have a C6500 and it has a 2220 code
C-2220 When the transfer belt motor
(M18) was ON, M18 abnormality
detection signal was continuously
detected for the specified
time.
solution
Printer control board (PRCB)
Transfer belt motor (M18)
2helpful
2answers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
