SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
SOURCE: Programming it to a Sylvanvia TV model 6420FF
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV
Code 006 for Sylvania TV
Code 008 for Sylvania TV
Code 019 for Sylvania TV
Code 062 for Sylvania TV
Code 068 for Sylvania TV
Code 069 for Sylvania TV
Code 075 for Sylvania TV
Code 076 for Sylvania TV
Code 077 for Sylvania TV
Code 088 for Sylvania TV
Code 116 for Sylvania TV
Code 130 for Sylvania TV
Code 132 for Sylvania TV
Code 134 for Sylvania TV
Code 161 for Sylvania TV
Code 183 for Sylvania TV
Code 196 for Sylvania TV
Code 353 for Sylvania TV
Thank you again for choosing Fixya.com
SOURCE: My Time Warner cable Remote will not program to my TV.
I had the same problem, so I followed these steps and it worked!
1) Turn on TV.
2) On the remote control, press TV once (it will blink once). Then press and hold SETUP until the TV key blinks twice.
3) Enter 9 9 1, (the TV key will blink twice).
4) Aim the remote control at the TV & press POWER once.
5) Press & release the CH+ key continously (you may need to press it more than 50 times!), then stop when the TV turns off.
6) Press POWER. The TV should turn on, then immediately, press SETUP to lock in the code.
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
