Please help me check for fragments in this sentence and create the right sentence showing where the commas and fullstop go
SOURCE: Optimizing WGR614(v1) for xbox live
the normal port that requires opening in your router for xbox is TCP3074, you should just type the number in as if there are no options, although there should be, it may know that 3074 is a TCP port.
SOURCE: battery replacement
Apart from taking it to a shop for a battery re-build, if you are savvy enough, you can re-build the battery by taking the old battery pack and the protection circuit board out with a soldering iron, keeping the plastic frame and replace the pack with a similar one that you can buy on ebay for less than US$10. Just search "Lithium Polymer 380mAh" and that is the one that gave mine a second life. WARNING: Do it at your own risk, don't hold me liable if you lose a finger or more from mishandling the potentially explosive Li-ion battery pack. Good luck!
SOURCE: xbox 360 live error code 0701/8000/4005
Im have having the same issue too!! So annoying!! Any news on how to fix?
