Question about Proton Televison & Video
I have a 37 inch proton tv that I can’t keep power on. What could be the problem?
  • Proton Master
  • 2,800 Answers
What exactly happens when the set shuts off?...does the power indicator lamp stay on, or does it blink. Also do you still have sound?
Posted on May 01, 2018
    Top Expert:
  • Proton Master
  • 54,195 Answers
Failing power supply
5 Suggested Answers
6ya staff
SOURCE:
coyotedave
  • 280 Answers
SOURCE: 37" LCD Flat screen
Yes it could and most likely is the power supply board. If you look at the capacitors on the board you may see some that appear swelled or puffed up at the top. If you see any that are puffed up they are leaky and replacing them may fix the problem. Some times if the Inverter board is bad it will not let the TV come on. a LED will be blinking. If you have no power at all it is most likely the power supply.
Posted on Jul 24, 2008
David Low
  • 458 Answers
SOURCE: 37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Posted on Mar 24, 2009
Chi Chu
  • 8457 Answers
SOURCE: 37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Apr 29, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: need a proton 37 inch stand for flat screen tv where can they be found
I would look for the internet site for this company and or with the model number Google it for base or mount etc.
Posted on Jun 11, 2012
My proton tv will not turn on
Check and replace its main power supply regulator [SMPS] as card basis. Contact any service technician for assistance. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Protron PLTV-37 37 in. LCD Television
How can I adjust the picture colors?
There are several performance issues you may encounter with your Protron PLTV-37C LCD television.
Some problems include the television not turning on, issues with the TV's picture and issues with the TV's sound.
Depending on the type of problem you encounter, there are several options available to you to solve it.
Power Issues
Check the TV's main power cord. If it is not plugged in or is loose, securely plug it in to an electrical socket.
Unplug the television and plug it in to another electrical socket.
If the one it is plugged in to currently is bad, the television does not receive power.
Try turning the television on with the remote.
If that does not work, try turning the television on with the power button on the TV's front panel.
If that works, then remove the battery cover from the remote.
Remove the current batteries and replace them with fresh batteries.
Picture Issues
Check the video cables.
If they are loose or disconnected, securely connect them.
Adjust the television's brightness.
If the brightness is set too dark, images on the screen are extremely difficult to see.
Check the power indicator on the front panel of the television.
If it is red, the television is in power-saving mode.
Simply press any button on the remote to bring the television out of power-saving mode.
Audio Issues
Check the audio cables. If they are loose or disconnected, securely reconnect them.
Turn to different channels and adjust the volume.
It is possible that some channels are coming in quieter than others.
Access the audio options from the main menu. Check what audio setting the TV is at.
If it is set to "Mono," change it to "Stereo."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dde1880d298054849d8c8adc90514f40&modelid=22971545&q=Proton+CS-37
Specifications for Proton CS-37 / PS-47
Aug 09, 2013 | Protron PLTV-37 37 in. LCD Television
54" TV HD MITSUBISHI TRN BY IT SELF...HELP
If a Mitsubishi (Proton is what is listed here) look on the back for the correct and full model number, no 54 inch sets, 55,60,73 etc.
Let me know if power light comes on for a few seconds and then goes off............
Dec 15, 2012 | Proton MM2701VT 27" TV
Need a proton 37 inch stand for flat screen tv where can they be found
Jun 11, 2012 | Televison & Video
Proton 34 LCD tv
Looks like Power Supply fuse is gone. Replace with recommended rating and type of fuse and try again.
May 18, 2008 | Protron PLTV-37 37 in. LCD Television
Lost power cord
Proton Introduces Elegant 37-Inch Puriti™ High-Definition LCD TV ... Each Protontelevision combines forward-thinking industrial design with the most ...
www.proton-usa.com
Nov 17, 2007 | Protron PLTV-37 37 in. LCD Television
Televison & Video Logo
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
