SOURCE: Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
SOURCE: Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
SOURCE: I need a diagram for the carburetor linkage on a
go to partstree.com and get a diagram for this.
hope this helps you.let me know.if you cant find it ill get you one ok.let me know
SOURCE: where do I find part numbers for my Ariens TR424
Go to this page: http://www.jackssmallengines.com/help.cfm
The choose menus:
Airens
Front tine tillers
RT424 4hp (note model and serial numbers!) pick yours
It will be 902026-xxxxxxx x= your number
There are 2 gearbox part numbers
1. 00201400
http://www.jackssmallengines.com/searchdb2.cfm?arisku=00201400&aribrand=Ariens&arireturnurl=http%3A%2F%2Fwww.jackssmallengines.com%2Fhelp.cfm%3Fario%253dgetAssemblyCollectionariamparipa%253dS4JA%252bvDiuhxnRQKPG3HpjA%253d%253dariamparica%253dVW4ZVMgDKUJOh%252fyuxQghxw%253d%253dariamparioem%253dT5AoXrwJ%252fdc5PmlGuX535Q%253d%253dariamparit%253dac83beea-d9ce-4586-92eb-5b37a36e4d95&ariqty=1
And
00287100 (Aluminum)
http://www.jackssmallengines.com/searchdb2.cfm?arisku=00287100&aribrand=Ariens&arireturnurl=http%3A%2F%2Fwww.jackssmallengines.com%2Fhelp.cfm%3Fario%253dgetAssemblyCollectionariamparipa%253dwRJIs3RYfQcbYmA%252bu%252bdCDA%253d%253dariamparica%253dYcaPzWhKx8%252f17NVu3Eh%252bXA%253d%253dariamparioem%253dlDrUqX7mT9VVQe1v8FlYOg%253d%253dariamparit%253d0713aa56-cc1e-4998-a4d2-4938cb172940&ariqty=1
That should be what your looking for. All of the seals and bearings can be found there also using the tedious menu search then selecting gearcase at the top of the picture.
Thanks for choosing FixYa.
Kelly
P.s I tried a net search for just the gearbox part number 00287100 with only one result. Seems you will have to use the menus.
Testimonial: "Thank you very much. I have now managed to find the part I want and it is being ordered. Hopefully delivered in 5 days. Cheers Jim"
