I added L1702 to your post as that is the real name. and is today, 15 years old.
Im guessing you meant black screen totally never text there.
does the monitor work on other PC as it must?? simple no?
if yes, it is good and the unstated PC is bad.
if not, the monitor is bad, if this old monitor is very old
2 things fail.
1: CCFL lamps inside all died long ago. 2010 or older.
2: the screen saver inside IT is turned on, turn that off.
push the menu button on the LCD monitor.
then in the OSD turn off sleep TIMER clock..
lets say unstated PC is dead.
1: is the fans dead,? if desktop 2 fans must be good, spin and blow air and not be packed up in lint as most old PC are.
heard ,seen to turn, and felt to blow.(air flow must happen)
2: does the DVD tray eject.
that PE monitor is old
this monitor has CCFL lamps
all burned out now from year 2000 to 2010
all did by now,
to prove this turn on PC known to work
then push the monitor menu button
see the OSD dead, (proof 1)
now use a flash light shine it at the dead screen, see data now?
YES. i see weak data, bingo CCFL DEAD.
bingo dead black lamp or the screen is in sleep mode.
so turn that off now.
i think that is 1702 version there.
2004, so if true is 14 years old
be happen it lasted that long.
for sure.
what does your tag show.
look like this, if yes tell more lines of data so we can ID the sucker.
ok that i s the model number but information on this monitor is all under, L1702 which you omitted.
this monitor has crummy CCLF back lamps
and has silly sleep timer (turn it off )
as you can see the above TAG photo is 2003
is yours that old?, this is key to fixing any old monitor, reading the tag and telling the blind helper here what the tag shows.
for model, and P/n there. and year. too .
for sure on CCFL bad
lamps that last only 20k hours.
yup
Try to tell what load means? please.
load?>
You cant see anything on the screen, (y/n)?
if the monitors OSD works
push the left front button on LCD lower side.
then pick managment.
then turn off power saver
then turn of sleep timer. there.
clues in your manual
Fully powered = Green. normal.
Sleep mode = Amber.
Sleep Timer mode = Flashing Amber.
read page 30 here, timer off
https://www.manualslib.com/manual/30069/...
now you have a free manual.
tell what load means and win.
cant see any thing ever, or only window fails
or not even text seen ever.
and is the menu key dead on front of monitor
is yes, hold the button for 10 to 30 second
to turn off button look on this L1702 monitor.
SOURCE: Monitor displays 'user mode' contrast icon @ 89%
Colin
If you can access the on-screen menu (see link below for manual) try and reset to factory settings.
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00385928/c00385928.pdf
If that doesn't resolve the problem, then also check and see if any of the control buttons are stuck, (Press button them flick finger away to try an release a stuck button)
If issue still exists, you can consult a TV repair shop, but essentially, then monitor is uneconomically repairable and it would be more cost effective to just replace it with an LCD monitor
SOURCE: I need Tech manuals/Schematics for LCD monitors
I need Tech manuals/Schematics for LCD monitors Compaq pe1231 p9622a 17 inch and HP vs15 MDL# hstnd-2l04 LCD monitors?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
490421200100R QLIF 041 HP 790421200A00R Power Supply Backlight Inverter
