Measuring Tools & Sensors Logo
J
Joan Rombough Posted on Apr 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Outdoor temperature is not being displayed , how can I fix this?
  • 3 more comments
  • Jean DeLauche
    Jean DeLauche Apr 30, 2018
    Hello, Joan - What is the make and model of your thermometer? I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Joan Rombough
    Joan Rombough Apr 30, 2018
    Nexxtech ultra slim wireless weather station model 6311598
  • Joan Rombough
    Hi Jean, did you get my info?
  • Joan Rombough
    Hi Jean?
  • Jean DeLauche
    Hello, Joan -
    I just saw your additional info. Note: Volunteers who answer for Fixya.com are not constantly monitoring replies to requests for added info. Eventually, we are notified by Fixya of added Comments. :) I will see what information I can find for you.
    Best wishes.
Jean DeLauche
Level 3:
  • Master 2,911 Answers
  • Posted on Apr 30, 2018
Jean DeLauche
Master
Level 3:
Answers
2911
Questions
Helped
974346
Points
13029
Hello, Joan -
I hope you have the user manual / instructions for your NexxTech weather station model 6311598. If so, I suggest you check the instructions on how to re-calibrate the sensor. See general information on weather station sensor maintenance (generic) here:
https://www.weathershack.com/static/ed-sensor-maintenance.html
I was hoping to find the home page for NexxTech (in hopes some troubleshooting information would be available), but it seems the company went out of business prior to 2015; maybe around 2003. (At least the trademark renewal for NexxTech was not filed by 27 Mar 2015.) NexxTech was a subsidary of InterTAN Canada Ltd., of Barrie, Ontario, Canada.
If you need an owner's manual / instructions for your weather station, so far, I have not found a website where I feel you (or anyone else) can safely download a manual (meaning: I don't trust the web sites where I found "download links" because I suspect malware will be installed on your computer with the download.)
There are some online discussion forums regarding weather stations. You may choose to register (free) on one or more of those forums and ask for help regarding resetting your NexxTech weather station properly. These are links to 2 forums I found:
http://forums.accuweather.com/index.php?s=5c410f2395384886437a35c171631c35&showforum=55
https://www.wxforum.net/index.php?PHPSESSID=c113f37f50bb469eaaf9622aaa675c61&#c7
Best wishes.
christopher martinez
Level 2:
Habit-Forming:
Filmmaker:
Uploaded 5 video answers.
  • Expert 37 Answers
Expert
Level 2:
Habit-Forming:
Filmmaker:
Answers
37
Questions
0
Helped
16540
Points
217
Check your temperature sensor, maybe you need to change this?
Testimonial: "I have taken down the sensor outside and changed the battery, did not help.. Seems to be in the settings."
1 Related Answer
Ron Reynolds
  • 433 Answers
  • Posted on Jan 02, 2018
SOURCE: Replacement Outdoor Temperature Sensor for Atomic Clock
Search the manufacturers website and ebay. It may require a little time and effort.
2answers
Radio Shack outdoor thermometer remote sensor 63-1026 reads LL.L Replacing batteries and reset didnt help. How to fix?
Try cleaning the outdoor thermometer transmitter unit by opening it up enough to spray compressed air (Ultra Duster or similar) on the temperature sensor. It fixed the hh.h error for me.
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Medion md41199 atomic clock, cannot get the outdoor temp to show, how to fix please
Remove ALL batteries in transmitter AND clock.
Insert new batteries in outdoor transmitter.
Insert new batteries in the (receiver) clock.
Wait until outdoor temperature is received AND displayed on clock BEFORE setting time/date/etc.
Top Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
