This should help you figure out what you need:
Sewing Presser Feet
SOURCE: faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
SOURCE: singer 6038
The presser bar is not moving, there is a set screw that controls the presser foot height on the bar, it may be to tight. Take the side cover off, and look for the presser bar, the set screw unit should be facing you. Unscrew it and see if the presser bar handel will now move.
The presser bar height should be set at 7 mm. To make an adjustment loosen the set screw. From the top of the machine, press down firmly on the presser bar and then secure the set screw.
SOURCE: The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
SOURCE: my presser foot lever wont
Make sure that your needle is in the highest position, turn your handwheel towards you, not away from or else you will mess up the timing
