Weatherproofing on back deteriorated and Raymarine discontinued the model and didn't provide any help so the multidirectional cursor is non functional. Ideas rather than duct tape are welcome! Thanks
SOURCE: I have a raymarine rl70
A replacement backlight is available from a company called Being Seen Technologies,
I believe their toll free phone number is 888 457-0117
good luck
SOURCE: Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
SOURCE: The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
SOURCE: My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Testimonial: "Factory reset solved the problem. Soft key next to power button worked a treat!"
SOURCE: I just bought a boat with a Raymarine C80 chart
Your problem is the 4GB card. The Raymarine C-Series have a problem with their compatability tool and larger CF cards. You should use a card no bigger than 256mb.
The card probably worked in the store because the newer models accept larger cards.
Get an older card from ebay etc and copy your 4gb files onto it and try again. There is more info here: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=1042&p_created=1089743435&p_sid=Y9eWB6ek&p_accessibility=0&p_redirect=&p_lva=1042&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjYsMjYmcF9wcm9kcz0zNiwzNTIsNDEmcF9jYXRzPTAmcF9wdj0zLjQxJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1zaXplIGNhcmQ*&p_li=&p_topview=1
Hope that helps you out.
