SOURCE: mercury 50 hp outboard
I actually thought it was down by the prop... i was wrong....
Pretty good diagram here.... look at part number 1
http://www.sterndrive.info/mercury-outboard-parts/60hp_to_125hp_component_layout.html
scroll down for the part cost and description.
Robert
Please take a moment to rate this solution.. thanks
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
SOURCE: mercury outboard 60 motor turning over but not firing up.
get some starting fluid and spray a liberal amount into the air intake, then try to turn over. if it will not turn over with starting fluid you have a problem either with your ignition system, example: plugs, coils, wires, ect. If it does fire and then die out with a shot of starting fluid then you have a carb problem. If the boat has been sitting anything over a month thats where I'm betting the problem is. Post back after you find out if its a fuel, or fire issue and we'll start the repair process.
SOURCE: 1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
