SOURCE: Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
SOURCE: Dryer Miele T9800- 3 years old Lately the air
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If your dryer is not drying like it once did or if you just have not
taken the time to give yourself a clean dryer in a long time then you
need to do that. At least once a year the dryer cleaning should take
place. Lint build up in the dryer duct is one of the main causes
for your dryer to fail.
Here is the rest of this tip about Dryer
Maintenance
heatman101
SOURCE: Miele T9800 dryer starts then stops and goes dead.
Hi, If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. check out this electric no heat tip... heatman101 ///
SOURCE: I have a Miele T9800
Hi - it makes me wonder as why we always tend to do things first prior to seeking the right/correct advice.
A T9800 Miele is not your everyday cheap dryer as you will know - the questions is have you still got your user Manual and if you do - have you read it carefully - it will tell where the problem lies and how to clean it.
I cannot grasp the fact that you would remove the rear access panel for a heater bank to check the resetable over temperature unit.
The machine clearly indicated a vent/filter error not a heat error - I know at this moment you have and are swearing & calling me names...
I will let you cool down a little ....................and I will tell you what you should have done instead of removing that panel Ok?
