SOURCE: connect positve and negative speaker wires
The slim terminal is the negative and the fat terminal is positive.
please rate, thanks
SOURCE: info on what colour rear speaker wires are on 2005 pontiac g6
Here are the radio wire colors of the whole system, please rate this solution.
2007 Pontiac G6 Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power or use the brown wire (+) at the ignition wire harness.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Pink
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
SOURCE: Suremark 4610 on Sure POS system/ Laptop T23
We specialize in these products.
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
[email protected]
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR,
IBM... We also offer structured cabling as well as Video Surveillance
Equipment.
Give us a call and we can trouble shoot it with you!
SOURCE: Chevy K5 Blazer military diesel with 12/24v
Positive of one battery to hot of vehicle wiring harness--neg. of that battery to positive of other battery--negative of that battery to block (ground)
SOURCE: I am trying to connect my infinity kappa series 52
THe amplifier connects to the crossover.. If you are using an amplifier there is no reason to connect the radio/deck to the crossover.
