I would assume you mean a Super Nintendo or Original Nintendo or N64 the answer is yes. Most TVs have a TV option or Coaxial or Aux input setting you just need to set the TV up to that setting and plug your console in. If your TV doesn't have the old fashion cable plugin or the proper plugins on the back of your tv you will need to get an adapter I recommend amazon. Coaxial to HDMI run about 20-30 dollars and composite adapters run about 10-20 dollars
SOURCE: hooking up game system to flat screen tv
you should have several kinds of inputs options on TV .If you have a surround audio receiver .Simply go direct to receiver on any available input .If using diect to TV , use any available input on TV .More likely VIDEO 1 or 2 (game or camera input)on front or side of flat panel
SOURCE: Problem with HD
go into the menu and see if you can Aline the convergence or try the magic focus see if you get an error
SOURCE: How do I connect a Nintendo 64 games system to a Hitachi TV?
Hi kdg 1026,
The wire from the Nintendo should have 3 plugs on the end. Yellow, Whit and Red.
OPn the baqck of the TV you have inputs that are color coded, Yellow, White and Red.
Plug the wires into the color coded inputs.
Turn on Nintendo.
Press input button on your TV remote until you get the picture.
Let me know if this helps.
Please rate this solution.
Lone99star
Btw, Iām available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: what cord do I need to attach tv to super nintendo game system
Here is a tutorial to hooking up a super nintendo
http://www.youtube.com/watch?v=9O4kjcXyZKI
