I had a brief look at the spec and it says the speaker outputs are banana sockets/plugs.
Once the four speakers are connected, or two with the fader control adjusted, it should produce good sound and if it does the next stage will be to connect the subwoofer with RCA plugs into the dedicated outputs.
I suggest you reread the manual.
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
You can even now turn off your subwoofer / adjust the volume easily now!
SOURCE: no sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
SOURCE: Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
SOURCE: connect powered subwoofer
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
