SOURCE: oil capacity of engine crankcase on 2007 Honda VTX 1800 C
The factory fill is 4.3 litres. Thats new empty lines...etc.
3.75 to 3.9 quarts is a normal drain.
Heres a link for the complete service manual on the VTX 1800C
It's a big download about 50MB in PDF format
Hope this helps...ride safe and ride smart.
SOURCE: 1984 mariner 5hp two stroke outboard wet sparkplug
Then it is flooding itself. You need to rebuild the carb and check your float level. Make sure to replace the needle and seat also because when they wear it will cause the engine to flood. I am 98% sure that will fix your problem!
SOURCE: 40 hp mariner outboard 2 stroke oil leak at
without seeing it in front of me its difficult to advise,i had a mercury but it wasnt oil injection so i iam not sure exactly how this injection system works but i should imagine its nothing more than a O ring thats perished or a copper washer needs cleaning with some wet and dry.I bought a new 4stroke mercury in the end because i got fed up with fuel consumption from the 80hp two stroke ,this four stroke 50hp will do about 12 14 nautical miles to roughly 6/7 litres of petrol at about 1200 rpm because iam only a sunday driver and the bumping on the waves makes my back ache unbearable,Well this is the land of fiesta /siesta /manaña --spain .Have a closer look and see where its leaking its only a mechanical pump running off the engine ,so it will have a push rod with some sort of diaphragm that pumps a tinysquirt of oil into the crankcase so it can mix with the incoming fuel ,nothing complicated
SOURCE: Fuel tank capacity & range 97 yamaha royal star motorbike
4.8-gallon, teardrop-style fuel tank (including a 0.9-gallon reserve)
It has a cruising range of more than 170 miles (273.58848 k)
SOURCE: i have a 15 hp
Remove top cover to find serial number on cylinder head.
Contact manufacturers here
http://www.marineroutboards.co.uk/main.php
